Upgrade AP to LAP
Apr 9th, 2007
Hi, I have the AP, AIR-AP1230B-A-K9, and I need upgrade it, so that it works like a LAP, How I do it?
Overall Rating: 3 (1 ratings)
Steven van Jaarsveld Tue, 04/10/2007 - 00:37
You first need to download the LAP code and the LAP Upgrade Tool from Cisco's website. Once done, you then create a .txt file with the information of the AP (IP Address, Username, Password, Enable Password) and insert it into the tool. The Tool has a built in TFTP Server and if pointed to the correct directory (where the LAP Code is) it will upgrade the AP automatically for you.
All Done!!
Cheers
Steven
Steven van Jaarsveld Tue, 04/10/2007 - 01:04
Hi Ricardo
I did some checking as well. Unfortunately the 1230B is not supported on the LWAPP Upgrade.
You will need to upgrade the hardware.
Cheers
Steven
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
