Key exchange failure
network27
Two routers connected together.
IPSEC IKE failure with following error message
"%CRYPTO-6-IKMP_MODE_FAILURE: Processing of Quick mode failed with peer"
Cannot understand what is wrong with following configs.
Assistance PLEASE
Router1#show run
Building configuration...
Current configuration : 1157 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname Router1
memory-size iomem 10
ip subnet-zero
crypto isakmp policy 100
hash md5
authentication pre-share
crypto isakmp key test address 192.168.10.2
crypto ipsec security-association lifetime seconds 86400
crypto ipsec transform-set Router1set esp-des esp-md5-hmac
crypto map Router1map 100 ipsec-isakmp
set peer 192.168.10.2
set transform-set Router1set
set pfs group1
match address 101
interface FastEthernet0/0
ip address 192.168.10.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface FastEthernet0/1
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router rip
network 192.168.1.0
network 192.168.10.0
ip classless
ip http server
access-list 101 permit icmp 192.168.1.0 0.0.0.255 192.168.2.0 0.0.0.255 echo-rep
ly
access-list 101 permit icmp any any echo
line con 0
line aux 0
line vty 0 4
login
end
Router2#show run
Current configuration : 1201 bytes
version 12.1
hostname Router2
ip subnet-zero
hash md5
crypto isakmp key test address 192.168.10.1
crypto ipsec transform-set Router2set esp-des esp-md5-hmac
crypto map Router2map 100 ipsec-isakmp
set peer 192.168.10.1
set transform-set Router2set
set pfs group1
match address 102
ip address 192.168.2.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0
no ip address
shutdown
interface BRI0/0
no ip address
shutdown
ip address 192.168.10.2 255.255.255.0
duplex auto
speed auto
interface Serial0/1
no ip address
shutdown
router rip
network 192.168.2.0
ip classless
ip http server
access-list 102 permit icmp 192.168.2.0 0.0.0.255 192.168.1.0 0.0.0.255 echo-rep
ly
access-list 102 permit icmp any any echo
line con 0
line aux 0
line vty 0 4
login
end
mfreijser
You could try to remove the following commands, as they are not necessary on VPN Tunnels between Cisco routers.
1) crypto ipsec security-association lifetime seconds 86400
2) crypto map Router2map 100 ipsec-isakmp
set pfs group1
Saving the configuration and restarting the routers could also help in some cases!
Hope this helps.
Michael
amansin
Can you try adding a default route on the routers and also permit IP in the interesting traffic access list.
ALso clear the SA's after the changes are made by using the following commands.
clear crypto isakmp
clear crypto sa
a default route is not necessary in this case, as it is a test-situation; the routers are directly connected to eachtother.
The 'IP' in the access-list is a good idea, i didn't even notice that he only had icmp in the list.
talisman1310
There might be a problem with the preshare keys. Check out this site...
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_tech_note09186a00801d55aa.shtml#s1a
Try this:
Router1:
crypto isakmp keytest address 192.168.10.2
Router2:
crypto isakmp keytest address 192.168.10.1
