H323 Cannot make outbound calls, OK Inbound
Apr 9th, 2007
I cannot make outbound calls, but inbound call is ok. We are installing 2 new T1's and have the first 5 channels up for testing, we have a test number 2580 coming in but when I make a call from the inside I get an error. Here's the dubug and the config:
*Nov 28 06:58:50.090: ISDN Se1/0:23 Q931: pak_private_number: Invalid type/plan
0x0 0x0 may be overriden; sw-type 2
*Nov 28 06:58:50.090: ISDN Se1/0:23 Q931: Applying typeplan for sw-type 0x2 is 0
x2 0x1, Calling num 8702
*Nov 28 06:58:50.094: ISDN Se1/0:23 Q931: Applying typeplan for sw-type 0x2 is 0
x0 0x0, Called num 16307909496
*Nov 28 06:58:50.098: ISDN Se1/0:23 Q931: TX -> SETUP pd = 8 callref = 0x0085
Bearer Capability i = 0x8090A2
Standard = CCITT
Transer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xE9808385
Exclusive, Interface 0, Channel 5
Net Specific Fac i = 0x00E3
Calling Party Number i = 0x2181, '8702'
Plan:ISDN, Type:National
Called Party Number i = 0x80, '16307909496'
Plan:Unknown, Type:Unknown
*Nov 28 06:58:50.166: ISDN Se1/0:23 Q931: RX <- CALL_PROC pd = 8 callref = 0x80
85
*Nov 28 06:58:50.182: ISDN Se1/0:23 Q931: RX <- PROGRESS pd = 8 callref = 0x808
Cause i = 0x8381 - Unallocated/unassigned number
Progress Ind i = 0x8381 - Call not end-to-end ISDN, may have in-band inf
o
*Nov 28 06:59:09.030: ISDN Se1/0:23 Q931: RX <- DISCONNECT pd = 8 callref = 0x8
085
Cause i = 0x8390 - Normal call clearing
*Nov 28 06:59:09.038: ISDN Se1/0:23 Q931: TX -> RELEASE pd = 8 callref = 0x0085
*Nov 28 06:59:09.090: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0
x8085
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
ip cef
no ftp-server write-enable
isdn switch-type primary-4ess
voice-card 1
password encryption aes
voice call send-alert
controller T1 1/0
framing esf
linecode b8zs
pri-group timeslots 1-24 nfas_d primary nfas_int 0 nfas_group 1
controller T1 1/1
framing esf
linecode b8zs
pri-group timeslots 1-24 nfas_d backup nfas_int 1 nfas_group 1
interface FastEthernet0/0
description Connection_to_Data_Vlan
ip address 10.XX.0.XXX 255.255.0.0
speed 100
full-duplex
standby 1 preempt
interface FastEthernet0/1
ip address 10.129.0.104 255.255.0.0
speed 100
full-duplex
h323-gateway voip interface
h323-gateway voip bind srcaddr 10.129.0.104
interface Serial1/0:23
ip address 10.1.1.1 255.255.255.0
no logging event link-status
dialer map ip 10.1.1.2 name megamap class megaplan megaplan
isdn incoming-voice voice
isdn T306 60000
isdn nsf-service megacom
no cdp enable
ip classless
ip route 0.0.0.0 0.0.0.0 10.129.0.1
ip http server
map-class dialer megaplan
dialer voice-call
dialer outgoing mega
control-plane
voice-port 1/0:23
voice-port 1/1:23
dial-peer voice 100 voip
tone ringback alert-no-PI
preference 1
destination-pattern 2580
session target ipv4:10.129.1.1
incoming called-number .
dtmf-relay h245-alphanumeric
codec g711ulaw bytes 80
no vad
dial-peer voice 1 pots
description PSTNpots
destination-pattern .T
direct-inward-dial
port 1/0:23
forward-digits all
gateway
emulate cisco h323 bandwidth
gogasca Mon, 04/09/2007 - 17:25
  • Green, 3000 points or more
Telco is disconnecting the call, I see that you are using NSF, could you please confirm with them that correct NSF is sent and switch is correct (isdn switch-type primary-4ess ) or what they are expecting from us in order to no disconnect the call?
BTW why you have dialer map ip configured under the serial?
tony.hanson Mon, 04/09/2007 - 18:27
I have verified that they are using NSF, when I remove it I get the following error:
*Nov 28 08:45:42.290: ISDN Se1/0:23 Q931: RX <- RELEASE_COMP pd = 8 callref = 0
x80B1
Cause i = 0x83E020 - Mandatory information element missing
I removed the dialer map, I don't know why the customer had it in there.
paolo bevilacqua Tue, 04/10/2007 - 00:28
  • Hall of Fame,
    Founding Member
more likely the problem is in the number format, have you tried local calls with seven digits? You are sending out a four digit extension, is that what they want? Also ask what type/plan they want in the setup message.
