CCME 4.1 problems: MWI & Meet-Me
Answered Question
Apr 9th, 2007
I am having a couple of problems with CallManager Express 4.1. My first issue is with MWI using Unity Express (2.3.2). When I leave a voicemail for a phone, the MWI is not turning on. The phone gets no visual indication that a voicemail has been left.
My second problem is with Meet-Me conferences. When I try to dialin to the meet-me conference (300) I get an engaged tone and a message on the phone says "could not complete conference".
Can anyone see what is wrong with my configurations (if at all)?
My CME config is attached as 'router1_confg.txt' and my CUE config is attached as 'router1-cue_confg.txt'.
Correct Answer by paolo bevilacqua about 10 years 3 months ago
you need:
sip-ua
mwi-server ipv4: expires 3600 port 5060 transport udp unsolicited
and, "mwi sip" under ephone-dn or ephone-dn-template.
I haven't fully checked your CUE config, but the above is missing for sure.
Hope this helps, if so please rate post!
Overall Rating: 5 (4 ratings)
wahab101 Mon, 04/09/2007 - 17:41
For the MWI lid to be on you need to add the incoming called number 80.... in the voip dial-peer that you configured for the CUE purpose as follows;
dial-peer voice 2 voip
so when you call and leave msg MWI will lid or retrieve the msg the MWI will go off
rvanderwaal Tue, 04/10/2007 - 14:59
Thanks for your reply.
I added the incoming called number 800... to the dial-peer voice 2 voip but it still does not light up the MWI on the handset.
If I manually call 800102, it will light up the MWI for extension 102. Then if I call 801102 it will turn off the MWI for extension 102.
For some reason though, when I leave a voicemail, it does not light up the MWI.
wahab101 Tue, 04/10/2007 - 15:18
Try following
Use a translation rule
voice translation rule 2
rule 1 /^408212/ //
Voice translation-profile CUE
translate calling 2
translate called 2
translate redirect-called 2
and apply this translation rule in both dial peer voip for voice mail pilot number
add another voip dial peer for the full digits
dial-peer voice 3 voip
description ** cue voicemail pilot number **
destination-pattern xxxx500 ( whatever your full digits did number is. Like 408212500
session protocol sipv2
session target ipv4:192.168.10.2
dtmf-relay sip-notify
codec g711ulaw
no vad
translation-profile outgoing CUE
Usually what happens is that CME things that CUE is in another box not afiliated with CME router so it reaches the CUE but it does not know how to come back from PSTN so you need to the second dial peer and the translation rule in it to route the response from CUE to the CME then to the IP Phones so the MWI lid or goes off. As you knwo it is the CUE who sends MWI on or off msg.
SO breifly you need two dial-peer voip for the voice mail pilot one with only 500 extnesion and the other with full digits dialing plan as you dial out to a local PSTN phone . Then you need to add translation rule to translate the called number
rvanderwaal Tue, 04/10/2007 - 15:47
You will have to excuse my knowledge, or lack there of it.
My system is a totally IP system that is not connected to the PSTN at all. It is being used as a seperate internal phone system across the corporate network for private communications between two groups. There is no plan to connect it to the PSTN or to the corporate phone system. It is to be treated as a seperate isolated IP phone system.
Correct Answer
paolo bevilacqua Tue, 04/10/2007 - 15:28
  • Hall of Fame,
    Founding Member
you need:
sip-ua
rvanderwaal Tue, 04/10/2007 - 15:55
Thankyou. I added the sip-ua and mwi-server lines, then changed the ephone-dns to "mwi sip" and now my MWI problem is fixed and working.
Appreciate the help on this.
Rob Huffman Wed, 04/11/2007 - 08:01
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Paolo,
Very nice work here! It is great to see so many problems solved by you. 5 points from this end :)
Take care,
Rob
wahab101 Mon, 04/09/2007 - 17:44
For the conference issue you need to look into your conference configuration under the Telephony-Service
as it seesm the problem arises from there. Make sure to add the line for the conference
manojpillai Mon, 05/21/2007 - 22:03
HI
you were able to sort out the conference issue ?
im facing same problem
pls reply
many thanks
cassio.gomes Fri, 02/22/2008 - 22:42
Hello Guys,
I have the same issue regarding MWI.
The envelope does not appear automatically after the message. But if I call 8000.... it appears. Please could anyone help me about this issue? Below the part of cisco router configuration
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
dial-peer voice 800 voip
incoming called-number 800[01]....
codec g711ulaw
no vad
sip-ua
mwi-server ipv4:192.168.31.133 expires 3600 port 5060 transport udp unsolicited
ephone-dn 9
number 8000....
mwi on
ephone-dn 10
number 8001....
mwi off
Cassio
