TUNNEL
Apr 9th, 2007
hi i m bit new to security......can someone plz tell me what is GRE tunnel....for that we have to make a tunnel first.....i m bit confused abt this concept....whast the dissrence between Gre and normal tunnel.....cheers and thnak sin advance
Overall Rating: 5 (1 ratings)
dgahm Mon, 04/09/2007 - 19:56
  • Blue, 1500 points or more
IPSEC tunnels can only handle unicast traffic, while GRE tunnels can also accommodate multicast, which is required for routing protocols like EIGRP or OSPF. So if you create a GRE tunnel, and then configure IPSEC to encrypt the GRE tunnel you get around this limitation of IPSEC.
http://www.cisco.com/univercd/cc/td/doc/product/core/7100/swcg/6342gre.htm#1057710
Please rate helpful posts.
spremkumar Mon, 04/09/2007 - 20:21
  • Red, 2250 points or more
In addition to David's explanation GRE is a simple encapsulation technology where in IPSEC provides you enough option for going in with different encryption strengths which you or your organization prefers as a policy to safeguard all your valuable information.
regds
