Catalyst 4948 SLB feature (server load balancing)
Apr 9th, 2007
Hi All,
Is it possible to enable SLB feature (server load balancing) on Cisco Catalyst 4948?
Now I have 12.2(25)EWA7 ENHANCED L3 IOS. It's a pity it hasn't SLB feature :(.
Thank you for answer.
Craig Balfour Tue, 04/10/2007 - 00:36
  • Bronze, 100 points or more
I don't think the Catalyst 4948 supports Server Load Balancing.
According to the Feature Navigator (http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp) the only Catalyst switch that supports SLB is the Catalyst 6500.
The datasheet for the Catalyst 4948 (with a list of features) is at http://www.cisco.com/en/US/products/ps6021/products_data_sheet0900aecd8017a72e.html
minko_at_work Tue, 04/10/2007 - 02:12
Is there ANY possibility to enable this feature (Server Load Balancing) on the switch?
Amit Singh Tue, 04/10/2007 - 02:15
  • Cisco Employee,
Nope, 4948 doesnot support SLB feature on it.
-amit singh
