Bypass PEAP user authentication
Apr 10th, 2007
Hello.
We use PEAP/MSCHAPv2 for client AND user authentication. Wireless users and clients will be authenticated by the ACS by asking a ADS usergroup membership. Only authenticated users on authenticated clients should have access to LAN ressources protected by the wlan controller. If the wireless client use the WZC and the logged on user is not a member of the user group he will not be authenticated and blocked by the wlan controller. But if the wireless client use the actual "Intel Wireless Pro Set" AND the user is not a member of the ADS group the ACS drop the user authentication request, but few seconds later the user will have nevertheless access to internal resources.
In this case I think the user authentication request will not right handled by the ACS so authenticated client will have access through the wlan controller and a not ACS authenticated user will have access to lan ressources by his local cached user credentials.
Is there a possible security leak or have I a configuration problem?
Best regards
Olaf Bachmann
dsweeny Tue, 04/17/2007 - 05:38
This is not a security leak but a configuration issue. If the client utility and the ACS, ADS database is correctly configured then you will not see any issues.
Trending Topics - Security & Network
