stacking 3550 switches
Apr 10th, 2007
Hello everybody.
Does the 3550 switches with EMI support stacking and is there any way of configuring it.
Overall Rating: 3 (1 ratings)
Amit Singh Tue, 04/10/2007 - 02:56
3550 switches doesnot support true stacking. You can connect them using Cisco's Gigastack GBIC module to make a switch cluster. the whole cluster will work on 1000base Half duplex. You can manage the whole switch cluster using a single Ip address.
HTH,Please rate if it does.
-amit singh
