H323 Client (Netmeeting) with IOS Gatekeeper
The environment consists of CM 4.1.3 , IOS GK and IP Phones and net meeting clients.
I would like to initiate calls from Netmeting clients to IP Phones and vice versa. What I find is that the IP Phones are able to call the netmeeting clients but not the other way around.
When doing a debug h225 asn I get the following output:
AF0100
*Apr 10 12:40:28.326:
*Apr 10 12:40:28.326: RAS INCOMING PDU ::=
value RasMessage ::= admissionRequest :
requestSeqNum 6
callType pointToPoint : NULL
endpointIdentifier {"46D6D0A400000003"}
destinationInfo
dialedDigits : "3165"
srcInfo
dialedDigits : "3199",
bandWidth 1
callReferenceValue 18180
conferenceID '86AD974CFD08524A8FAC8BFE9663A075'H
activeMC FALSE
answerCall FALSE
canMapAlias FALSE
callIdentifier
guid '80FCEEB9BD01E14AAEB146F1C33B5BAF'H
willSupplyUUIEs FALSE
*Apr 10 12:40:28.330: H225 NONSTD OUTGOING PDU ::=
value ARJnonStandardInfo ::=
callReleaseSource gatekeeper : NULL
iecInfo
'10201190000E0000'H
*Apr 10 12:40:28.330: H225 NONSTD OUTGOING ENCODE BUFFER::= 80E00160090110201190
000E0000
*Apr 10 12:40:28.330: RAS OUTGOING PDU ::=
value RasMessage ::= admissionReject :
requestSeqNum 6
rejectReason invalidEndpointIdentifier : NULL
nonStandardData
nonStandardIdentifier h221NonStandard :
t35CountryCode 181
t35Extension 0
manufacturerCode 18
data '80E00160090110201190000E0000'H
*Apr 10 12:40:28.330: RAS OUTGOING ENCODE BUFFER::= 2D000564B50000120E80E0016009
0110201190000E0000
*Apr 10 12:40:31.846: RAS INCOMING ENCODE BUFFER::= 0E4021CD060008914A0002000100
0A0201FEE02701000A0201FEC5B708800228780A0501004040100280007A006F006E006500310062
00B50000120E8E02003B0180211E0034003700420030003600430038003400300030003000300030
0030003000320100
*Apr 10 12:40:31.846: RAS INCOMING PDU ::=
value RasMessage ::= registrationRequest :
requestSeqNum 8654
protocolIdentifier { 0 0 8 2250 0 2 }
discoveryComplete FALSE
callSignalAddress
ipAddress :
ip '0A0201FE'H
port 57383
rasAddress
ipAddress :
ip '0A0201FE'H
port 50615
terminalType
gateway
protocol
h323 :
}, voice :
supportedPrefixes
prefix dialedDigits : "1#*"
mc FALSE
undefinedNode FALSE
gatekeeperIdentifier {"zone1b"}
endpointVendor
vendor
t35CountryCode 181
t35Extension 0
manufacturerCode 18
timeToLive 60
keepAlive TRUE
endpointIdentifier {"47B06C8400000002"}
Any ideas, I have tried playing around with the different codecs supported on the netmeeting client.
your input would be appreciated.
MikeTomasko Tue, 04/10/2007 - 18:47
  • Bronze, 100 points or more
Have you tried adding the NetMeeting clients as H.323 end points?
Here are the instructions for configuring Netmeeting in CallManager:
Step 1 Open Cisco CallManager.
Step 2 Select Devices > Add a Device.
The Add Device page displays.
Step 3 Select Device Type > Phone >Next
Step 4 Select the appropriate model from the Model drop-down list. In this case you need to select H.323 Client> Next A new window will be displayed
Step 5 In Device Name put the ip address of the PC or laptop that has the Netmeeting.
Leave other parameters as default and click Insert.
Step 6 Click an unassigned line (Line 1, Line 2, and so on).
A new window will be displayed.
Step 7 In Directory Number put the extension for the Netmeeting device.
Leave other parameters as default and click Insert and Close.
Follow these step in the NetMeeting Client:
Step 1 Go to Tools>Options.
In the General section click the Advanced Calling button that is located at the bottom.
A New window will be displayed.
Step 2 In the Gateway Settings section select "use a gateway to call telephones and videoconferencing systems" In the Gateway field put the IP address of the CISCO CALLMANAGER SERVER.
Click Ok>Ok.
