Passive & Non passive!
Answered Question
Hello Netpro!
IF we have a Dist switch connected to CORE Thr Portchannel;AND THIS Dst has 10 L3 Interfaces;EIGRP IS THE Routing protocol
Why its recomended to configure all L3 interfaces as Passive interface & the Portchannel as non passive interface.is any matter regrding performance or EIGRP Best practice?WHY IN THIS ISSUES WE CONFIGURE THE PASSSIVE INTERFACE?
regards
ALI
Correct Answer by sundar.palaniappan about 10 years 1 month ago
Ali,
If a layer 3 interface isn't passive EIGRP will send multicast (224.0.0.10) hello packets on that segment looking for neighbors. If there's another device on the same segment that runs EIGRP they will become neighbors and will exchange routes between them.
Sundar
Overall Rating: 5 (3 ratings)
Jon Marshall Tue, 04/10/2007 - 05:21
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Hi Ali
If the port channel is layer 2 then you cannot make all your l3 interfaces passive otherwise there won't be an EIGRP neighbourship between the core and distribution switches.
if the port channel is layer then yes you can make your EIGRP L3 interface passive. This aids in troubleshooting and unnecessary EIGRP updates across the links.
Jon
Jon Marshall Tue, 04/10/2007 - 06:51
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Sorry Ali, that should say
"if the port channel is layer 3 then yes you can make your EIGRP L3 interfaces passive".
Jon
Correct Answer
sundar.palaniappan Tue, 04/10/2007 - 09:27
  • Green, 3000 points or more
Ali,
Sundar
