IP Video Conferencing requirements
Apr 10th, 2007
Our company is planning to implement IP video conferencing for H.O. and four remote branches. The remote branches are connected to HO by 512kbps leased line. Now, what do I need to implement this requirement. What specific Cisco equipments do I need to and place to my network.I really appreciate if someone can help me on this requirement.
Thank you very much.
Paolo Bevilacqua Mon, 04/16/2007 - 10:27
Also cisco CCME support video conferencing using Cisco VT advantage or the videostation 7985. Interoperate with other vendor should not be a problem. It is a feature of IOS and runs on all the routers so you can chose from the 2801 and upward.
Hope this helps, if so please rate post!
