Number of VLAN and STP Instance on Sup 2 WS-X4013+
Answered Question
Apr 10th, 2007
I have a Catalyst 4006 with Supervisor 2 WS-X4013+
I want to create more than 200 VLANs on the switch, with as many STP instance.
Is it possible with this Supervisor Card?
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I9S-M), Version 12.2(18)EW2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Mon 01-Nov-04 16:23 by kellythw
Image text-base: 0x00000000, data-base: 0x010BAF04
ROM: 12.1(20r)EW1
Dagobah Revision 90, Swamp Revision 3
HDD_Sw uptime is 30 weeks, 5 days, 23 hours, 55 minutes
System returned to ROM by reload
System restarted at 16:37:24 GMT+1 Fri Sep 1 2006
System image file is "bootflash:"
cisco WS-C4006 (MPC8245) processor (revision 4) with 262144K bytes of memory.
Processor board ID FOX063610MX
Last reset from Reload
2 Virtual Ethernet/IEEE 802.3 interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
26 Gigabit Ethernet/IEEE 802.3 interface(s)
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Correct Answer by Amit Singh about 10 years 1 month ago
Please paste the show mod output.
If its Sup2+ running IOS, then yes you can configure that. Sup2+ supports 2K active vlans with 1.5K STP instances.
http://www.cisco.com/en/US/products/hw/switches/ps4324/products_data_sheet09186a0080197424.html
HTH,Please rate if it does.
-amit singh
Overall Rating: 5 (1 ratings)
