CallManager 5 SNMP string
Apr 10th, 2007
I'm trying to add an SNMP string to Call Manager. It says that the string is added successfully and that the SNMP Master Agent is restarted. However, when I do a query to find it, it says there are zero strings configured. Does anyone know why it won't add it?
thisisshanky Tue, 04/10/2007 - 10:36
I just tried this on my CM 5.1, used a freeware SNMP tool like SNMP Get/Set and it seems to work just fine.
thisisshanky Tue, 04/10/2007 - 11:01
Yes it did. I added it in Publisher and then selected the option to push it to all nodes.
kbeckman Tue, 04/10/2007 - 11:40
No matter what I do, it just doesn't add it. It says it does, but it never is listed. Is there a way to add using the CLI?
