H.323 can not make outbound calls
Answered Question
Apr 10th, 2007
Srs,
I have a Tandberg video conference that is configured in callmanager wich h.323 client. When i use the tandberg to make a call, the call is disconnect, i belive for telco.
THIS IS OK ! MAKE FROM TEL IP !!!
Apr 10 18:32:42.860: //-1/802E1084BE06/CCAPI/cc_api_display_ie_subfields:
cc_api_call_setup_ind_common:
cisco-username=Claudio
----- ccCallInfo IE subfields -----
cisco-ani=21288257
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=1
cisco-anisi=1
dest=0213134951223
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
cisco-redirectreason=-1 fwd_final_type =0
final_redirectNumber =
hunt_group_timeout =0
THIS IS NOT OK ! MAKE FROM TANDBERG H.323
GW-VOICE#
Apr 10 18:31:19.932: //-1/00639752BB06/CCAPI/cc_api_display_ie_subfields:
cisco-username=192.168.1.5
cisco-ani=
cisco-anitype=0
cisco-aniplan=0
cisco-anipi=0
cisco-anisi=0
dest=0213134951223
cisco-desttype=0
cisco-destplan=0
cisco-rdie=FFFFFFFF
cisco-rdn=
cisco-rdntype=-1
cisco-rdnplan=-1
cisco-rdnpi=-1
cisco-rdnsi=-1
When i try a call through a mobile out , the call is ok !
obs: In my LAN when i call from tandberg for a Tel IP, the number of tandber don't appear in the display of Tel IP.
Correct Answer by lpezj about 10 years 3 months ago
I had a similar problem with the 7985 video phone. I solved my problem adding the next command to the voice-ports: bearer-cap Speech.
In this case, I was trying to send only voice calls.
Hope this helps,
Juan Luis
Overall Rating: 5 (1 ratings)
paolo bevilacqua Tue, 04/10/2007 - 13:41
  • Hall of Fame,
    Founding Member
Are you using ISDN? If so, can you provide output of "term mon" and "debug isdn q931" when placing a successful and unsuccessful call ?
Correct Answer
lpezj Tue, 04/10/2007 - 23:13
  • Gold, 750 points or more
Hope this helps,
Juan Luis
