Internal WIC-1AM Modem
Apr 10th, 2007
We have gone with the WIC-1AM modem module for our console routers. However, upon dialing in, I get a quick hangup by the WIC-1AM, debugs show the following:
*Apr 10 08:35:29.775: Modem (0/0) DCD Asserted
*Apr 10 08:35:29.799: Modem (0/0) DCD UnAsserted
My config is here:
router#sh run | begin line aux 0
line aux 0
exec-timeout 30 0
password 7 XXXXXXXX
script reset sportster
login authentication modem
modem Dialin
modem autoconfigure discovery
transport input all
stopbits 1
speed 300
flowcontrol hardware
line 0/0/0
stopbits 1
speed 115200
Thanks in advance for any suggestions!!
zahmed Wed, 04/11/2007 - 21:27
Hi Dan,
WIC-xAMs are sensitive to line voltage. So you might want to try a different phone line on it and see how that works.
By the way, if you are reverse-telnetted into the WIC, and now you dial in, do you see RING ?
Also try to dialout from reverse-telnet mode and see if that works.
Thanks and Regards,
~Zulfiqar
dasmith Thu, 04/12/2007 - 04:40
Thanks for reply. I was able to do as you suggested, using atdt command to dial my desk phone, and observed RING, when an incoming call was placed. Still investigating, but no progress yet.
dasmith Thu, 04/12/2007 - 04:55
I went to another router with WIC-1AM installed and performed a 'debug modem' on that device while attempting a dial in. Here is what I collected:
Apr 12 08:51:18.318: Modem (0/2) DCD Asserted
Apr 12 08:51:18.658: TTY0/2/0: DSR came up
Apr 12 08:51:18.658: Modem 0/2/0 WIC-AM: in modem state 'Connect'
dte = modulation= Unkn protocol = compression_type = NONE tx_speed = rx_speed =
Apr 12 08:51:19.657: tty0/2/0: Modem: IDLE->(unknown)
Apr 12 08:51:19.661: TTY0/2/0: EXEC creation
Apr 12 08:51:19.677: TTY0/2/0: create timer type 10, 30 seconds
Apr 12 08:51:19.709: Modem (0/2) CTS UnAsserted
Apr 12 08:51:19.749: Modem (0/2) CTS Asserted
Apr 12 08:51:19.765: Modem (0/2) CTS UnAsserted
Apr 12 08:51:19.801: Modem (0/2) CTS Asserted
Apr 12 08:51:23.965: Modem (0/2) DCD UnAsserted
Apr 12 08:51:24.657: TTY0/2/0: DSR was dropped
Apr 12 08:51:24.657: TTY0/2/0: Quickly dropping DTR
Apr 12 08:51:24.657: tty0/2/0: Modem: READY->HASPROC
Apr 12 08:51:24.657: TTY0/2/0: pause timer type 10 (OK)
Apr 12 08:51:26.657: TTY0/2/0: Line reset by "Exec"
Apr 12 08:51:26.657: CHAT0/2/0: Attempting line reset script
Apr 12 08:51:26.657: CHAT0/2/0: Asserting DTR
Apr 12 08:51:26.657: TTY0/2/0: Modem: HASPROC->HANGUP
Apr 12 08:51:26.657: TTY0/2/0: no timer type 0 to destroy
Apr 12 08:51:26.657: TTY0/2/0: no timer type 1 to destroy
Apr 12 08:51:26.657: TTY0/2/0: no timer type 3 to destroy
Apr 12 08:51:26.657: TTY0/2/0: no timer type 4 to destroy
Apr 12 08:51:26.657: TTY0/2/0: destroy timer type 10
Apr 12 08:51:26.657: TTY0/2/0: no timer type 2 to destroy
Apr 12 08:51:27.657: TTY0/2/0: dropping DTR, hanging up
Apr 12 08:51:27.657: tty0/2/0: Modem: HANGUP->IDLE
Apr 12 08:51:29.656: TTY0/2/0: restoring DTR
Apr 12 08:51:29.656: TTY0/2/0: Modem get info started
Apr 12 08:51:32.164: TTY0/2/0: Modem: ATS86? -> 021OK
Apr 12 08:51:34.764: TTY0/2/0: Modem: ATZ -> OK
Apr 12 08:51:36.748: TTY0/2/0: Modem: AT&F\V1S0=1 -> NO CARRIER
The 'Unkn protocol' at the top may be the key.
