04-10-2007 11:00 AM - edited 03-10-2019 03:33 AM
We are trying to setup a 2811 router to run IOS based IPS. We followed all the procedures but we can't seem to get the system to send any alerts via syslog. We have tried various port scanners with no luck. Are we missing something?
04-10-2007 11:03 AM
Can you provide more details about your IOS image and configuration that you have.
For latest IOS T-train image, you can try the getting started guide at http://www.cisco.com/en/US/products/ps6634/products_white_paper0900aecd805c4ea8.shtml.
With more information, I can better answer your questions.
-Chris
04-10-2007 11:12 AM
Here is the IOS version:
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Experimental Version 12.4(20070215:163920) [jenneyc-V124_11_T1 107]
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Sun 11-Mar-07 12:16 by jenneyc
Also, this is the only message we got that might be considered a IDS alert. But we don't get any alerts when we perform normal port scans.
<188>2459: Apr 10 15:04:47.885: %IPS-4-SIGNATURE: Sig:2157 Subsig:1 Sev:75 [10.15.250.30:0 -> 10.11.100.61:0] RiskRating:63
rtrwan-anf000#sho ip ips configuration
Configured Config Locations: flash:ips5/
Last signature default load time: 16:57:56 est Mar 14 2007
Last signature delta load time: 12:03:57 est Apr 10 2007
Last event action (SEAP) load time: -none-
General SEAP Config:
Global Deny Timeout: 3600 seconds
Global Overrides Status: Enabled
Global Filters Status: Enabled
IPS Auto Update is not currently configured
IPS fail closed is disabled
Fastpath ips is enabled
Quick run mode is enabled
Event notification through syslog is enabled
Event notification through SDEE is disabled
Total Active Signatures: 1090
Total Inactive Signatures: 899
IPS Rule Configuration
IPS name testips
IPS Category CLI Configuration:
Category all:
Retire: False
Category viruses/worms/trojans all-viruses/worms/trojans:
Retire: False
Category p2p bittorrent:
Retire: False
Category p2p edonkey:
Retire: False
Category p2p kazaa:
Retire: False
Category reconnaissance:
Retire: False Alert
Interface Configuration
Interface FastEthernet0/0.1
Inbound IPS rule is testips
Outgoing IPS rule is testips
Interface FastEthernet0/0.2
Interface Serial0/0/0
Interface Serial0/0/0.34
Interface Serial0/0/0.35
04-10-2007 11:33 AM
Your configuration seems ok. Can you please provide the following output:
1. show ip ips signature (as attachment)
2. What port scanning tool you used and how you used it.
Your configuration has syslog/sdee enabled.If you have configured syslog server properly, the ips alerts will be sent to syslog server. So the question is whether IPS actually working and will be able to trigger events as expected.
If you know how to use metasploit, you can try use that to test it. "3Com 3CDaemon FTP Server Overflow" should trigger signature 3166/3173. (Use 'show ip ips signautre | in 3166' to check, it should show something like "3166:0 Y Y A HIGH 0 1 0 0 0 FA N 100 S190")
-Chris
04-11-2007 11:06 AM
Try enabling sig 2004, ICMP Echo Request and then ping the interface of the router that has the IPS policy attached to it.
