Part Numbers for Cisco Unified Communications 500 Series for Small Business
Apr 10th, 2007
Hello.
Does anyone have a part number for the Cisco Unified Communications 500 Series for Small Business? I can find the part number for the companion switch that expands it out to handle 16 phones but nothing on the main part itself.
Also, adding the companion switch adds support for 16 more phones does anyone know if you can add a second companion switch for a total of 24 phone supported? If yes then what is the limit on the number of phones that can be added to this new solution?
Thanks in advance!
All replies rated
Overall Rating: 4 (2 ratings)
thisisshanky Tue, 04/10/2007 - 11:36
Travis,
Reading from q&a for these products, it looks like FCS is sometime in June and will be orderable in May 07.
Paolo Bevilacqua Tue, 04/10/2007 - 12:10
Hi Travis,
if you need more info, pls contact your sales channel. There is a document they can access that answers these questions.
