CCM4.0 Backup and upgrade to 4.2
joe2065
Hello I new to CCM. I have in lab cisco 7800 server with 4.0 installed i like to backup, and up grade to 4.2 can some one tell me how to proced with this.
Second question i have same ccm 4.0 i have 4 phones i need to connect the call manager and without poe switch. But i have local power for the phones and i have unmanged switch and 1800 router and pix 501. please help. thanks
thisisshanky
Level 11
Level 11
According to this doc, you can directly upgrade from 4.02a to 4.2(3).
http://www.cisco.com/en/US/products/sw/voicesw/ps556/prod_software_versions_comparison.html
You can download the 4.2 upgrade file from CCO
http://www.cisco.com/cgi-bin/tablebuild.pl/callmgr-42
For phones to register with Callmanager, you need to setup phones with a static TFTP address or if using DHCP, your DHCP scope should have a custom option 150 defined with the ip address of TFTP server. The TFTP server should be one of the callmanager servers running TFTp service. (typically the Publisher itself)
Sankar
PS: please remember to rate posts!
Sankar Nair
UC Solutions Architect
Pacific Northwest | CDW
CCIE Collaboration #17135 Emeritus
joe2065
I have the new 4.2 call manager software full package from cisco. What i want to know is that i want to bakcup the data before i upgrade and how do i do that
You will need to install BARS (Backup and Restore System). Its either available on your 4.2 discs set or you can download it from CCO. (The link i pasted before should help). Using BARs you have to dump the database into a tar file and move it off the server. I usually take a system backup using Ghost, Acronis etc just in case.
Sankar Nair
Also this document should have detailed steps.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_installation_guide_chapter09186a00807202d7.html
Sankar
Sankar Nair
