Issue with NAT Both Directions, encapsulation failed
Apr 10th, 2007
Hi, i need help, im trying to configure NAT for both directions (Source address an Destination Address).
I have 4 Networks.
Network A 172.16.25.0
IP ADDRESS NAT INSIDE B 172.16.111.124 OVERLOAD
IP ADDRESS of the HOST C 172.16.18.22
IP ADDRESS NAT OUTSIDE STATIC 10.24.137.3
When an IP of Network A is trying to reach an IP fo Network C, first the IP of Network A (Source) i have to change for one IP of Network B., after, the IP of Network C has to be natted for one IP of the Net D
Router
________
IP 172.16.25.79 to Reach 172.16.18.22 -->| NAT |--> 172.16.111.124 to reach 10.24.137.3
|________|
I have this Configuration
ip nat pool NAT_pool 172.16.111.124 172.16.111.124 netmask 255.255.255.128
ip nat inside source list Access_NAT pool NAT_pool overload
ip nat outside source static 10.24.137.3 172.16.18.22
ip classless
ip route 0.0.0.0 0.0.0.0 172.16.70.1
ip route 10.24.137.0 255.255.255.0 172.16.111.1
ip route 172.16.18.22 255.255.255.255 FastEthernet0/1.111
ip access-list extended Access_NAT
permit ip host 172.16.25.79 10.24.137.3 0.0.0.0
interface FastEthernet0/0
ip address 172.16.70.250 255.255.255.0
ip nat inside
duplex full
speed 100
interface FastEthernet0/1.111
encapsulation dot1Q 111
ip address 172.16.111.124 255.255.255.128
ip nat outside
no cdp enable
When i do tests i can reach the IP 172.16.18.22, but when i check sh ip nat translations
Pro Inside global Inside local Outside local Outside global
icmp 172.16.111.124:512 172.16.25.79:512 172.16.18.22:512 10.24.137.3:512
--- --- --- 172.16.18.22 10.24.137.3
and with the command sh ip packet i got this issue
*Jun 15 01:14:54.582: IP: s=172.16.111.124 (FastEthernet0/0), d=10.24.137.3 (FastEthernet0/1.111), g=10.24.137.3, len 60, forward
*Jun 15 01:14:54.582: IP: s=172.16.111.124 (FastEthernet0/0), d=10.24.137.3 (FastEthernet0/1.111), len 60, encapsulation failed
Anyone knows what is the cause that i cant reach the Destination IP???
rtanner Tue, 04/10/2007 - 19:36
Encapsulation failed means the router knows the interace but not the next hop MAC address. Since NAT order of operation from in to out is to route then NAT, I suspect the route for the outside local address is incorrect.
try changing,
to
ip route 172.16.18.22 255.255.255.255 172.16.111.1
refs:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800a6057.shtml
and NAT order of operation
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080133ddd.shtml
Ross
qr_israel Thu, 04/12/2007 - 13:21
Thanks, its working.
Just i only changed the route.
i did a ping to destination and it responded.
