When QoS applied, 7206 router generates input errors on ingress interface
Apr 10th, 2007
When I apply QoS configuration, 7206 router generates input errors on ingress Ethernet interface (fa1/1). Does anybody have similar experience?
QoS setting:
policy-map Outbound-Queuer
description Provides outbound queuing.
class Routing
bandwidth percent 4
random-detect dscp-based
class Mission-Critical-Data
bandwidth percent 10
class Transactional-Data
bandwidth percent 30
class Network-Management
bandwidth percent 5
class Bulk-Data
class Scavenger
bandwidth percent 1
class Proxy
bandwidth percent 15
class class-default
fair-queue
policy-map Outbound-Queuer-Shaper
class class-default
shape average 1000000
service-policy Outbound-Queuer
policy-map Inbound-Marker
description Colours inbound traffic on a LAN interface.
class Routing
set ip dscp cs6
set ip dscp 25
set ip dscp af21
set ip dscp cs2
class Bulk-Data
set ip dscp af11
class Scavenger
set ip dscp cs1
class Proxy
set ip dscp af43
class class-default
set ip dscp default
interface FastEthernet1/0
service-policy output Outbound-Queuer-Shaper
interface FastEthernet1/1
service-policy input Inbound-Marker
Errors:
Input queue: 0/75/61/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1265000 bits/sec, 1447 packets/sec
5 minute output rate 1624000 bits/sec, 1463 packets/sec
2098432647 packets input, 3156190990 bytes
Received 10899486 broadcasts, 0 runts, 0 giants, 0 throttles
26739 input errors, 0 CRC, 0 frame, 0 overrun, 26739 ignored
0 watchdog
Tried different IOS: C7200-JK9S-M), Version 12.4(8c) and (C7200-ADVENTERPRISEK9-M), Version 12.4(11)T1
Same problem.
spremkumar Tue, 04/10/2007 - 20:08
  • Red, 2250 points or more
Did you try to clear the counters and check ?
regds
wencong.yan Tue, 04/10/2007 - 21:53
Thanks for reply. I tried many times. Sometime the errors are up to 55k per hour.
Even I only applied QoS config in one interface. Eg. int fa1/1 service-policy input Inbound-Marker. No service-policy out on another interface.
It could be something to do IOS. The old 12.3-13 seems no that many input errors. However, there were more encryption type of errors.
Cheers,
Cheers.
paolo bevilacqua Wed, 04/11/2007 - 03:37
  • Hall of Fame,
    Founding Member
Which NPE are you using?
Is this a PA-2FE ? If so, watch out because the particular hardware is seriously troubled at handling sustained traffic and can exhibit problems like you are having. You should replace it with two single-port FE PA's.
This said, you might try to alleviate the problem doing a troubleshoot on input drops and possibly buffer tuning. See for a start:
http://cisco.com/en/US/products/hw/modules/ps2033/products_tech_note09186a00800d76e5.shtml
The document is titled for ATM but can be applied to all media.
Hope this helps, if so please rate post!
wencong.yan Wed, 04/11/2007 - 17:44
Thanks for reply. It is a PA-2FE. We have changed a new one. Also the input errors appear on the other router on different site. If no QoS, there is no error at all.
paolo bevilacqua Wed, 04/11/2007 - 18:13
  • Hall of Fame,
    Founding Member
Hi, my previous comment about performance trouble was actually related to an older 2-FE card, so please ignore it.
I think you have CEF enabled ? Which NPE is that? Significant processing power is needed to process sizeable amount of traffic with a marking policy complex like your. Perhaps you could simplify it a little?
wencong.yan Wed, 04/11/2007 - 19:51
Hi, CEF has been enabled. It's NPE400. This is very strange case. Even I took out input marker from ingress interface and just applied service policy out on egress interface. It still generates input errors on ingress interface. If none of QoS config applied on both interfaces, then no errors on ingress interface at all. The egress interface has no error whatever QoS config applied or not.
pciaccio Wed, 04/11/2007 - 04:08
  • Silver, 250 points or more
The issue is with your Input Queue. The FIFO hardware buffer is getting saturated. You have applied a Policy map to the input of your interface. Try increasing the HOLD Queue IN on the Fast Ethernet. It is currently set for 75 packets. Set it for 125.
Interface Fast Ethernet 1/1
Hold-Queue in 125
Do not make this value too large it increases your final stage FIFO buffer. If too long then you will add too much delay, if too short you will still incur errors....Good Luck...
wencong.yan Wed, 04/11/2007 - 17:48
I have tried tunning buffers. Whatever I change the Hold-Queue size, it still generates errors. With old IOS, it didn't have so many input erros. I'll try down grade the IOS.
Many thanks,
