Cisco VPN Client password popup
Apr 11th, 2007
We are starting the Cisco VPN client from running the ipsecdialer.exe command. If the user types an incorrect password we would like the username/password popup box to appear. This works well in our old version (4.0.2.B). However with the new client ( the popup window does not appear. Instead an "authentication failed" window appear.
We are using the same pcf file. The following command is run:
ipsecdialer.exe /c /sd /user <user> /pwd <pass> "<profile>"
I would very much appreciate if anyone knows how to make the password popup window also work in the new version.
(Is there e.g. an option in an ini file?)
Best regards,
net-harry Tue, 04/24/2007 - 06:40
We have still not been able to resolve this problem. Does anyone have any idea how to fix this issue?
Thanks in advance!
