04-11-2007 03:52 AM - edited 03-14-2019 08:55 PM
Does anyone have a sample idle URL graphic for the 7970 phone? We have tried creating one following Cisco instructions but receive a Parse error 4 on the phone itself? Thanks.
Solved! Go to Solution.
04-12-2007 05:40 AM
Yes, this is the case. I tested it with a 7970. Any larger than 125x60 and you get the error you mentioned.
Brandon
04-11-2007 04:57 AM
The following link explains the process of creating an idle url graphic.
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_tech_note09186a00801c0764.shtml
The one thing not mentioned is that you need to put a copy of the .xml AND the .gif file in the C:\CiscoWebs\IPPhoneServices\CCMCIP folder.
Hope this helps. If so, please rate the post.
Brandon
04-11-2007 05:55 AM
Can you tell me whether including the .gif file is also relevant for IDLE URL graphics? Of course for backgrounds they are.
Is there a link for the customisation of 7970 phones, for backgrounds, idle url's etc? Thanks
04-11-2007 06:09 AM
Yes, including the .gif is necessary for idle url graphics as well. Take a look at the following link.
Brandon
04-12-2007 01:59 AM
We have tried many combinations but unfortunately still get the XML error [4]: Parse Error.
1)The path from the phone to the publisher is correct, http://xxx.xx.xx.xxx/CCMCIP/7970.xml
2)Have included the GIF file as suggested, in the same directory.
3) The picture dimensions are 320 x 234
Any help would be appreciated here.
04-12-2007 04:16 AM
The image can be no larger than 125x60 according to the following link.
Brandon
04-12-2007 05:31 AM
Brandon is this defintely the case? As I believe this document refers to the 7940 and 7960 phones, the screen resolution is greater on the 7970. We have tried several combinations but no luck.
04-12-2007 05:40 AM
Brandon
04-12-2007 07:46 AM
Well done Brandon, seems like the idle image can only handle the 125x60 resolution. It's a shame that it cant handle higher res.
Muarrij
