How to add a new Local quarantine?
Apr 11th, 2007
I have a C100 and want to add a new local quarantine but the button "Add Quarantine..." was dim. There is a message beside the button.
"No space available for additional quarantines."
How can I add a new local quarantine?
bvanzant_ironport Wed, 04/11/2007 - 12:36
You'll need to edit one of the existing quarantines and lower the amount of space it is currently using. If you take away 512MB from, for instance, the Policy quarantine you can then create a new quarantine that is up to 512MB in size.
