WCS config group / audit
Apr 11th, 2007
I've a trouble with config group in WCS 4.0.97 with the following step:
- set-up 2 templates ( server authentication )
- selected 3 controllers in the same mobility group
- applied these 2 templates to the controlles ( all worked fine )
- checked with audit on these templates ---> mismatch ( !?!? )
Do I forget something ?
many thanks
Luigi
Anonymous (not verified) Tue, 04/17/2007 - 08:00
Here, is it like you have applied these 2 templates to 3 controllers. So, all these 3 controllers you are trying to apply them to the same mobility group?. Can you clarify this?
LUIGI PIETRONAVE Tue, 04/17/2007 - 12:04
yes all 3 controllers are in the same mobility ( they was already in the same group ) and I apply, with the GROUP-CONFIG 2 templates.
All is successful, but when I make the audit i get a mismatch.
The "good" news is that I found a bug: CSCsg46060
regards
Luigi
