Pb using WLC4400 with ASA5510
Apr 11th, 2007
I'm trying to use a Cisco ASA5510 to replace a 3750 router in a configuration with a WLC 4400.
The solution works fine with the router but not with the ASA.
Anyone knows if there is specific configuration to do on the ASA?
Does the inspection engine drop any packets ?
Thanks for your help.
Nordine IDIRI
Telindus
sbenoliel Mon, 05/21/2007 - 13:28
be carfull, you can't connect directly ASA5510 and WLC4400, the speed of the WLC4400 is only 1G and not 100M like interface of the ASA. TYou must use a switch or ASA5520 with gigabit interface.
Trending Topics - Security & Network
