Configure 6509 Switch to disable a chattering port
Apr 11th, 2007
IS there a way to configure a cisco 6509 switch ports so that if there is a bad switch or NIC card that is chattering and re-transmitting information, the corresponding port should be disabled.
Thanks for your help.
