Simple Video - CCM Question
Apr 11th, 2007
When configuring the bandwidth settings in Call Manager "Locations" for Audio, you place a value there for the total amount of BW that CM will allow for voice calls from a given location.
The question I have is the value for video calls the same way (cumulative) or is it a per call value?
Also, if one video call is 384kbps, plus overhead, does that include the 28kbps for the audio portion or do you add that in addition?
Thanks!
Overall Rating: 4.5 (2 ratings)
Brandon Buffin Wed, 04/11/2007 - 10:22
  • Purple, 4500 points or more
The video bandwidth is for all video calls to the location. The bandwidth for a video call includes the audio portion.
Hope this helps. If so, please rate the post.
Brandon
mparella Wed, 04/11/2007 - 10:30
Great thanks, Brandon! Will Rate for sure. So if I anticipate having a max of 3 simtaneous video calls from a location @ 384 kbps, I should add approx. 20% per call (76kbps) for overhead and use a number like 1.38 mbps as my bw?
Thanks again.
