FWSM NAT question
Apr 11th, 2007
I have a question about natting on the FWSM. We want to move a few servers to an outside VLAN but we also want to still be able to hit them using the old inside IP's. Here's the basic set up:
interface Vlan80
nameif outside
security-level 50
ip address 172.16.1.254 255.255.255.0 standby 172.16.1.253
interface Vlan91
nameif outside-servers
security-level 55
ip address 172.16.2.254 255.255.255.0 standby 172.16.2.253
interface Vlan100
nameif inside
security-level 100
ip address 10.10.3.254 255.255.255.0 standby 10.10.3.253
The inside vlan the servers were on is 192.168.20.x/24.
Old IP:
192.168.20.100
New IP:
172.16.2.100
I'm assuming I'm going to have to set up a static nat and route that host on the 6509 to 10.10.3.254?
srue Wed, 04/11/2007 - 11:12
how about changing the order of a static nat entry? instead of (inside,outside), change it (outside,inside)...
or in your case:
static (outside-servers,inside) 192.168.20.100 172.16.2.2
as well as the proper static route.
niro@optonline.net Thu, 04/26/2007 - 21:06
That didn't work...I keep getting a no translation error on the pix log when I try to connect to it...and when I do a show xlate I'm not seeing 192.168.20.100 at all (or the 172.16.2.2)...
acomiskey Fri, 04/27/2007 - 10:29
I think he meant...
static (outside-servers,inside) 192.168.20.100 172.16.2.100
did you try that as well, that is called Destination NAT and should do the trick.
