VPN cant ping other subnets
Apr 11th, 2007
i have a cisco vpn concentrator 3000 series that cant ping the branch office subnets. i havent made any changes and it worked before. i can ping devices on the same LAN as the vpn. any ideas?
thanks in advance.
Hieu Cao Wed, 04/11/2007 - 16:06
Do you have a default route and static route in the VPN? If they're not there, then add them to the VPN device.
hth,
hieu
jerry.mcrae Wed, 04/11/2007 - 16:28
default -> 65.x.x.x
172.16.1.0/255.255.255.0 -> ethernet 1 private
along with others for example
10.10.0.0/255.255.0.0 -> ethernet 1 private
Hieu Cao Wed, 04/11/2007 - 17:04
There's a "router address" field that should point to your internal device that does the routing (ie: l3 switch). Is that field empty? If it's blank, then try filling in the gateway ip address.
Take a look at the System Status under Monitoring, is Memory Status "green" or "red". If it's red, you'll need to reboot the vpn box.
