Router Files in Flash
Apr 11th, 2007
I have a 3745 router running 12.2 IOS. I am trying to rename some files in flash (name.old)and TFTP some new files in to test. This seems pretty straight forward, any help would be appreciated. Will rate.
mparella Wed, 04/11/2007 - 13:21
Thanks. I only have "flash" not "bootflash". When I do issue the command though, I get "error opening flash:new-name (Device in exclusive use)" Ideas?
situwayne Wed, 04/11/2007 - 13:50
RouterA#sh flash
-#- --length-- ---------date/time--------- path
1 24696600 Feb 28 1993 16:13:20 -08:00 c3745-advipservicesk9-mz.123-4.T4.bin
2 1888 Feb 28 1993 16:14:32 -08:00 sdmconfig-36xx-37xx.cfg
3 16264 Feb 28 1993 16:14:40 -08:00 sdm.shtml
4 3176448 Feb 28 1993 16:15:42 -08:00 sdm.tar
5 1462 Feb 28 1993 16:15:54 -08:00 home.html
6 216064 Feb 28 1993 16:16:06 -08:00 home.tar
7 22966284 Feb 28 2002 16:11:04 -08:00 c3745-jk9o3s-mz.123-10.bin
12791808 bytes available (51089408 bytes used)
RouterA#rename flash:c3745-advipservicesk9-mz.123-4.T4.bin test.bin
Destination filename [test.bin]?
RouterA#copy tftp flash
Address or name of remote host []? 10.150.204.21
Source filename []? c3745-jk9o3s-mz.123-11.bin
Destination filename [c3745-jk9o3s-mz.123-11.bin]?
RouterA#delete flash:c3745-advipservicesk9-mz.123-4.T4.bin
Delete filename [c3745-advipservicesk9-mz.123-4.T4.bin]?
mparella Wed, 04/11/2007 - 13:55
Thanks for the response. Unfortunately I do not have "rename" as an available command in any mode.
mparella Thu, 04/12/2007 - 04:03
It does somewhat. I am unsure what a "class c" file system is in flash. Am I to understand that I cannot rename anything in my flash if the command is not available?
Will rate the response. Thanks.
MUHAMMAD SHAHEEN Thu, 04/12/2007 - 07:12
If you are unable to rename a file then you may want to copy that file to a new name (copy File2 file3)
then delete file2
Hope this Helps
Shaheen
