04-11-2007 01:05 PM - edited 02-21-2020 01:28 AM
I have a Windows environment with a PIX 515E firewall. We have site-to-site VPNs as well as VPN clients.
I have just installed ACS 4.1 and would like to configure it to do vpn client authentication againt Active Directory.
Can someone please post a link to a doc which describes this? I have been looking all day!
Thanks in advance,
Paul
Solved! Go to Solution.
04-12-2007 09:59 AM
If you remove the
vpngroup
from the PIX it should then use local username/passwd.
04-12-2007 09:30 AM
04-12-2007 09:47 AM
Thanks for the response. I actually figured this out since I posted the question yesterday. However, now I have a new question. I already have a client VPN set up on the PIX (6.3, btw) and I don't want to affect the current setup. I found how to exclude xauth from site-to-site VPNs, but is there any way that you can exclude current vpngroups from xauth?
thanks,
Paul
04-12-2007 09:59 AM
If you remove the
vpngroup
04-12-2007 10:26 AM
Very good!
Paul
