Using Avaya Modular Messaging?
Apr 11th, 2007
Anyone have a integration between Unity and Avaya Modular Messaging? I?d like to hear how you did it and if you used PIMG, etc.
Ideally I wanted to have a 7960 linked via PRI/QSIG to Avaya 8700/800 that has AMM integration, but I don?t believe that will work.
-jason
thisisshanky Wed, 04/11/2007 - 14:40
Reading AMM's documentation, it looks like Octel integration is suppported. I am not sure about other options such as PIMG, VPIM etc..You could network Unity with AMM using Cisco Unity Bridge (which is a separate product).
Note that you dont need to network voicemail systems together, unless you want to send messages from one system to another. Not sure if that is exactly what you are looking for.
