TFTP Server
Apr 11th, 2007
Hello everyone,
I'm looking in to building a TFTP server. When backing up configuration data, is it possible to back it up to a windows server on the network, or does it have to be backed up to a router on the network?
Usually, when you run the tftp backup command, it requires a file name, where is this backup file located by default.
spremkumar Wed, 04/11/2007 - 20:08
Hi Danny
Most of the times you tend to backup the IOS file and the config files.
You need to check out on which path the files are saved in your router.
They will be in the flash and you can mention the path accordingly.
Before starting up the backup process you need to verify the path in the router or the storage where the files are stored.
Once you are done with that you can define the same accordingly while doing the tftp backup process..
regds
desai.jaideep Wed, 04/11/2007 - 20:37
Apart from the others, make sure that you give different filenames for each destination config file, b'coz all the routers config file is same named "router-config".
You can use free TFTP servers available like 3CDeamon, Solarwinds etc.They are better then normal win TFTP.
JD
terrygaowei Wed, 04/11/2007 - 23:22
Hi Danny
I believe you are trying to backup your switch/router running config right?
you may install TFTP server at any platform, linux or windows. as long as you have control of your TFTP server.
Bring up your tftp server,and set the tftp file location.
if you are backup CatOS config. then use this command :
Cisco>(enable)copy config flash
if you are backup IOS config, then use this
cisco#copy run tftp
All your backup files will diretly push to your tftp file folder.
About file name,you could use any name you like. Eg: backup-2007-04-12
Terry
NCS,Singapore
danny9797 Thu, 04/12/2007 - 09:17
Thanks for the replies everyone.
jbeltrame: what format must the file be in? Where should I place the file, c:/ ? When the router prompts for the file name, do I insert the full path?
spremkumar: how can I view or change the path on the router?
deasi, thanks for the suggestions, i'll look in to the freeware apps.
Terry, yes I would like to backup the iso along with the configurations. Thanks for the tips.
jbeltrame Thu, 04/12/2007 - 17:46
the file will go into the root of the tftp server. The file can be any name you choose. For example, say the root of the tftp server is c:\tftpd. You can create a file called router/2007041101. Then, when you save the file via tftp, it will be like:
router#copy run tftp://TFTPSERVER/router/20070411
danny9797 Sat, 04/14/2007 - 08:47
Thanks for the response.
I want to do some testing here at home. I have a friend with Solarwinds, so im going to give it a try. If I setup a TFTP server with solarwinds, would I be able to test it out using a simulator? I have Boson netsim, does anyone know if this would work out or would I need physical hardware for testing?
Thanks again
desai.jaideep Sat, 04/14/2007 - 09:03
I think you can stimulate saving running-config on BOSON. But u need a real router for backuping an IOS.
Pls rate helpful posts.
JD
