Q on DSP
Apr 11th, 2007
hi
i have a question on DSP simple calcultions in mind without using the cisco dsp calculation tool, for example if i want to support 12 simultaneous conference bridges with 4 participants each what is the number of dsp's required
is there any table that talks about the capacity of one dsp for Conferencing, transcoding, termination,...
thanks
johnnylingo Mon, 04/16/2007 - 13:03
  • Bronze, 100 points or more
Check out tables 5 and 6 of this link:
http://www.cisco.com/en/US/products/ps6441/products_configuration_guide_chapter09186a0080541bf3.html#wp1003287
So for termination, each DSP can do the following:
(16) with G.711
(8) with G.729a or G.729ab
(6) with G.729 or G.729b
# of DSPs per PVDM on 2800 and 3800 series:
PVDM2-16 = 1
PVDM2-32 = 2
PVDM2-48 = 3
PVDM2-64 = 4
user-cisco Wed, 04/18/2007 - 01:49
thanks johnnylingo for reply
first: i think according to the tables it is (8) with G.711 for transcoding not (16) with G.711.
second: what is meant by (8) with G.729a or G.729ab
is it if transcoding from g711 to either g729a or g729ab?
also, for (8) with G.711 the transcoding from what to what?
and in case of transcoding to pstn what the pstn codec of the call (the transcoded call codec?) is it G711?
appreciate any helpful posts
johnnylingo Wed, 04/18/2007 - 11:35
Right, the sample numbers I posted above are for TERMINATION, not transcoding. For transcoding, if you are going from G.711 to G.729a or G.729ab, each DSP will do 8 sessions. For G.729 and G.729b, the number is 6.
There's no such thing as transcoding to the PSTN. That's what voice termination is.
paolo bevilacqua Wed, 04/18/2007 - 14:14
  • Hall of Fame,
    Founding Member
For a nitpick, there is companding conversion going to PSTN (transcompanding? what a word!), where g711a is used.
