allow-connections Removed?
Apr 11th, 2007
I am running the latest 12.4(11)T and
12.4(11)T1 ip plus images on AS5400HPX's
I no longer have an
allow-connections option under
voice service voip
and sip 2 sip calls are failing like they
used to pre 12.4 ?? I can't find any documentation of this removal? or changes
to allow voip to voip connections?
paolo bevilacqua Thu, 04/12/2007 - 15:03
  • Hall of Fame,
    Founding Member
Hi, I'm not quite sure how it was "before" but right now an IP-to-IP gateway image (and license) is needed for such calls, filename ends in _isv.
s.broadbent Thu, 04/12/2007 - 15:36
There are no ipipgw images for the AS5400HPX,
the allow-connections command was introduced
around 12.4 I believe and is still available
in the 12.4 ios variants except for
the 12.4T releases. The latest 12.4(13a) ip plus
has the command. My understanding is that
the 12.4T train should have everything from
12.4 plus all new features.. not less?
paolo bevilacqua Fri, 04/13/2007 - 03:59
  • Hall of Fame,
    Founding Member
Hmm perhaps for the as5xxx the feature was in advanced service images for .T or something like that. Then sometime release managers can get wrong what is supposed to be in a given release or feature set, and fix it eventually.
