Gateway problem
Apr 11th, 2007
I have a router 1600 that is at the back of a PIX 520. The router is configured to simply route all traffic to the internet thro 10.0.0.10
No traffic routes thro the router, the config is below. Does this look in order?
version 12.0
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname Websense
ip subnet-zero
no ip routing
interface Ethernet0
ip address 10.0.0.15 255.255.255.0
no ip directed-broadcast
no ip route-cache
interface Ethernet1
ip address 192.168.201.254 255.255.255.0
no ip route-cache
ip classless
ip route 0.0.0.0 0.0.0.0 Ethernet0
no ip http server
end
Websense#
mahmoodmkl Wed, 04/11/2007 - 23:15
  • Gold, 750 points or more
First enable IP routing it is disabld.
10.0.0.10 i assume is the IP of the PIX inside interface,if its then define the default route pointing to this IP and check.
Mahmood
stantcd Thu, 04/12/2007 - 01:02
thanks
Yes, .10 is the pix. I thought routing was already enabled. would the static route to ethernet0 for all routes not forfil this function then? Do i need the default-gateway command instead?
John
victory_cm Thu, 04/12/2007 - 02:10
No need to give Default-gateway command..Just enable IP routing..That will do.
