CNA5.0problem(not connect to edge switches)
Apr 12th, 2007
Hi there,
I have a 4507R Device. Also some Edge Switches connected to them. If I connect with the Cisco Network Assistant I can see the 4507R Core Switch and all the Edge Switches. This is ok. But In all other visible Switches Im not able to see front pannel and others topolagy table even i enable ip http server, cdp on . If I connect directly with the CNA to this Switches, it works. But I want to operate the whole Network over my Core Switch & cna 5.0. Thanx alot
