Get Ip Address from a device in CM 5.1
paulogentile
In CM 4.2 i just use this url:
https://172.16.200.1/ccmadmin/getdeviceip.asp?devicename=SEP00059A3C7800
but in CM 5.1 i can?t use.. someone know if have a similar url in cm 5.1 or a better way to get the ip adress?
secall
Hi Paul,
The '5.0'+ way is to use the AXL Serviceability API.
I'm fairly certain that this web page is gone altogether.
Seth
It is definitely so.. there's no ASP on Linux for starters. If you check the developer guide for the 5.x releases, it'll specifically mention the changes required in getting IP addresses of phones.
I try to get by AXL RisPort but i only get error.. e need ip in real time so i send a command to address: https://172.16.200.202:8443/realtimeservice/services/RisPort/
but nothing happend.. if someone have an example to get ip address and works fine, post here..
Paul--
Are you passing it a valid web service request as defined by the WSDL?
Like this guy is doing (http://forums.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Unified%20Communications%20and%20Video&topic=IP%20Phone%20Services%20for%20Developers&CommCmd=MB%3Fcmd%3Ddisplay_location%26location%3D.1dde1fa5)
Although he's hitting an error himself...
