Implementing VLANS
Apr 12th, 2007
Hello
I m Athar.My company has approx: 350 LAN clients.All these clients reside in one private ip range.We have 12 departements in the company.
Now there is a need to implement VLANS in our existing LAN scenario.
We have one router,one ASA-5520 ,and number of layer 2 managable switches.
What criteria should we adopt to implement vlan in our network.Should we need more routers or not.What should be the ip scheme.
Thanx in advance.
Bye
mahmoodmkl Thu, 04/12/2007 - 04:57
I would recomed you to configure a switch as a VTP server,and rest of the switches as vtp clients.Connect the switches with eachother and configure that ports as trunk ports.
Create the vlans on u r vtp server,this will propogate the vlan info on all the switches.
Segment u r users according to department or buildings or floors.assign each vlan for each segment for this u will need to have a seprate subnet for each vlan.
Does u r router capable of doing intervlan routing.first confrim this.
Mahmood
I would recomend u to create vlans per each floor or building.
