Problem with routing...
Apr 12th, 2007
I just installed a 6509 running ios. This 6509 connections two server irons (Foundry, switch like). On the 6509 I have multiple servers connected to it. I can ping all my networks but one. 10.7.1.x/24 (from these servers connected to the 6509). I can ping the router interface 10.7.1.254, but I cannot ping anything else. This only happens when I'm on a server on the 10.4.x.x/16 network. From the 6509 I can ping anything on the 10.7.1.x network. Any ideas why
Thanks so much.
Mike C.
Amit Singh Thu, 04/12/2007 - 05:36
Mike,
Where are both the subnets located. On the same 6509 switch or other switch. Howz the network topology. Please attach a brief network topology and config for more understanding
HTH,
-amit singh
pciaccio Thu, 04/12/2007 - 05:42
Mike:
It is a little difficult to diagnose without some sort of configuration off the 6509. However did you check your default gateways off the servers and are they correct for their respected VLAN's that they are on?
pciaccio Thu, 04/12/2007 - 09:10
This problem may stem from an OSPF issue. Can you verify that your OSPF process is working. I see no area 0 in your configuration. I hope you have an area 0 in your configuration because you need it. Do a show ip route and verify your subnet routes are all there.
