CM 5.1 upgrade problems
carenas123 Wed, 04/18/2007 - 12:32
  • Silver, 250 points or more
After Upgrading to CCM5.1, the default codec will change to g.722. Try disabling and fix it to G.711.
G722 is a wideband codec which takes no more bandwidth than G711 but has much better audio clarity and quality.
Either change all region to 722 or 711. this might happen due to codec mismatch
