IDS-4210
Answered Question
Apr 12th, 2007
I noticed that the model IDS-4210 does not do INLINE inspection on software 5.1(3)
Will it do on newer versions ? or the 4210 cannot do it period ?
Correct Answer by marcabal about 9 years 10 months ago
Yes and No
The scheme you wrote up is right, but it does NOT route between vlan 1 and vlan 2.
The IPS will instead switch or bridge packets between vlan 1 and vlan 2.
What this means is that the IP Address on the router's vlan 1 interface MUST be in the same IP Subnet as the IP Address on the inside vlan.
The IPS will simply take the packets on vlan 1 and put them on vlan 2 (and vice versa), it will not "route" packets between 2 IP Subnets so the same IP Subnet must be used in both vlan 1 and vlan 2.
Overall Rating: 5 (3 ratings)
marcabal Thu, 04/12/2007 - 07:09
There are 2 types of inline inspection:
inline interface pairs - 2 physical interfaces are paired together and the inspection is done inline as the packets are passed between the 2 interfaces
inline vlan pairs - 1 physical interface is connected to a switch using a trunk port, 2 vlans on the trunk port are paired together and the inspection is done inline as the packets are switched between the 2 vlans
The IDS-4210 only have one monitoring interface, and so you can not create inline interface pairs.
But the IDS-4210 Does support inline vlan pairs on that one monitoring interface.
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/csids/csids12/cliguide/cliinter.htm#wp1057307
Rodrigo Gurriti Thu, 04/12/2007 - 10:48
Thank you
But one more question
The 4210 would have to act like a router to direct the packets from the internet to the inside network ?
I tried to look on configuration guides but they have no examples.
I assume that the network scheme would look something like this:
router ---vlan1
IDS ---vlan1/2
inside ---vlan2
am I right ?
PS. thank you marcabal for your post
Correct Answer
marcabal Thu, 04/12/2007 - 11:01
Yes and No
