AAA and Cisco MDS switches.........
Apr 12th, 2007
have configured Cisco ACS 4.0 (TACACS) with Windows AD for all Cisco MDS switches and it is working fine. But local "admin" access to the Cisco MDS switches via telnet is not working. At the same time , if I create a user with "network-admin" role locally, that works but not the default admin user.
Could anyone help me in this regard.
hegleran@yahoo.com Thu, 04/12/2007 - 07:22
SAK Mohan,
Are you authenticating against local or line after tacacs? Local will authenticate to a local username/password. Line will authenticate to the password on the vty line.
SAK_Mohan Thu, 04/12/2007 - 07:32
local. Below is the script I used to configure TACACS (Cisco ACS 4.0) on Cisco MDS switches.
config t
# Enable TACACS+
tacacs+ enable
tacacs-server host nnn.nnn.nnn.nnn key 0 xxxxxx
tacacs-server host mmm.mmm.mmm.mmm key 0 xxxxx
# Specify TACACS+ Server groups
aaa group server tacacs+ tacgrp
server nnn.nnn.nnn.nnn
server mmm.mmm.mmm.mmm
aaa authentication login default group tacgrp
aaa authentication login console local
# Enable TACACS+ Accounting
aaa accounting default group tacgrp local
end
copy running-config startup-config
MOhan
hegleran@yahoo.com Thu, 04/12/2007 - 07:44
Mohan,
Do you have a local username called admin created? Or are you trying to login as admin, and then using the vty password when there is no admin account created?
SAK_Mohan Thu, 04/12/2007 - 07:49
Thanks.....
Yes....it is there which is the default/local "admin" user that comes with Cisco MDS switches. I am using the right password.
This we need as a backdoor to Switches in case TACACS fails for some reason.
MOhan
colin.mcnamara Thu, 04/12/2007 - 14:13
  • Bronze, 100 points or more
if you want it as a backdoor (for default login)
you need to add local at the end of your statement.
the following statement
should be modified to
aaa authentication login default group tacgrp local
That will enable you to authenticate with a local account (assuming you have configured a local cli user) in the event of a AAA server outage.
--Colin
SAK_Mohan Thu, 04/12/2007 - 15:17
THat is what I haebeen tying to configure....but unfortunately "local" option after "aaa authentication login default group tacgrp" is not available in Cisco MDS if i press Tab.
One more thing is..without the local option , I am able to login using locally created users with "netwok-admin" role but not the default "admin" user.......
--Mohan
