PIX515e and PDM access
Hi All,
I have trouble logging into PDM from the inside interface. I can connecgtg ok but I think the process fails at authorization stage. The follwoing message is posted in the browser status window:
exception: java.Security.AccessControlException: Access Denied (java.util.PropertyPermission java.version read).
I have console access to the firewall and have added an admin user using
username <name> password <password> priv 15 command.
I am using the admin user to access PDM.
Please advise.
bthibode Fri, 04/13/2007 - 06:37
Hi P.
Please ensure your browser is running a supported version of java. Also, you should have something like this in your config enabling pdm access:
http inside
After you've checked those two things, please ansure that you do, in fact, have PDM installed in the flash mem of the PIX.
