IPv6 and Switch compatibility
Collin Clark Thu, 04/12/2007 - 08:29
Looks like it's not officially supported. From the command reference on cisco.com:
"Layer 3 IP version 6 (IPv6) packets are treated as non-IP packets."
Looking at the switch matrix it looks like the 3560's are the lowest model that supports IPv6.
HTH and please rate.
Harold Ritter Thu, 04/12/2007 - 10:09
I don't see any issue to pass IPv6 traffic through the 2950. The issue is if you want to manage the 2950 via IPv6 as it is not supported.
Hope this helps,
