Serial Interface VoIP/RTP QoS
Apr 12th, 2007
Hi there,
I'm wanting to setup some sort of VoIP/RTP QoS on a 2MB link between a satellite site and HQ. I have approx 20 handsets at the remote site. I have setup the following QoS rules on both remote and HQ routers, 2620's with IOS 12.2.
Router-HQ#sh run
call rsvp-sync
controller E1 1/0
class-map match-all class1
match access-group 101
policy-map policy1
class class1
bandwidth 2048
random-detect
random-detect precedence 0 32 256 100
interface Serial0/0
bandwidth 2048
encapsulation ppp
ip tcp header-compression iphc-format
ip rtp header-compression iphc-format
ip rtp compression-connections 64
ip rtp reserve 16384 100 800
Router-HQ#
I am trying to implement a more aggressive queue QoS method than just ip rtp header-compression?
Does anyone have any recommendations regarding my bodged attempt??
Much appreciated, Cheers!
Brandon Buffin Fri, 04/13/2007 - 09:41
  • Purple, 4500 points or more
Take a look at the QoS SRND.
QoS SRND
http://www.cisco.com/application/pdf/en/us/guest/netsol/ns432/c649/ccmigration_09186a008049b062.pdf
Specifically, look at the following sections.
WAN Aggregator QoS Design -> WAN Edge Classification and Provisioning Models
WAN Edge Link Specific QoS Design -> Frame Relay -> High-Speed
This should help you with classifying and prioritizing traffic.
Hope this helps. If so, please rate the post.
Brandon
chrispresland Tue, 04/17/2007 - 02:32
Hi Brandon,
Apologies for the late reply!
Thanks for your input and guidance. I shall be applying some new configuration soon so will let you know how it turns goes!
Best Regards,
Chris
