Message Notification at random times (Newbie)
Apr 12th, 2007
We've just finished an install of Unity. Our field folks have a mailbox on the server, and we set notification to their cell phone via device pager. Works great, but they are all getting a missed call from the 1800 number associated with the system - at 0130 in the morning. Not all users are getting the calls at the same time.
I ran the Port Usage analyzer, and there are zero dial outs during that period. Setting the enabled hours has eliminated the calls, but I still don't know what caused the calls in the first place. Is there any kind of "new day" event that I might have missed that's perhaps flushing these calls back to the cell phones? Any other ideas would be great.
Tommer Catlin Thu, 04/12/2007 - 11:46
  • Green, 3000 points or more
What time is your MWI syncng going on? Maybe that is triggering it for some reason
Christopher McAlpin Thu, 04/12/2007 - 15:23
  • Cisco Employee,
First I would suggest that they set up SMTP notification or SMS notification to their cell phones if possible, it's much nicer.
But back to your issue. I can't explain why the port usage analyzer is not showing any port usage at that time, possibly that is a seperate issue.
However, the way that notifications currently work is if you have a schedule set up for notifications like for example 8am to 5pm, each day at 8am, if you still have a new message, then a notification will be sent.
Another thing that will cause what seems like a random notification is if you have new messages, and either Unity or the mailstore (Exchange/Domino) has gone off line and come back on line.
Perhaps their is some maintencace going on around the 1:00am hour?
