MGCP & Fractional E1
Apr 12th, 2007
Can anybody confirm whether it is possible to configure a single 2851 Router to support both MGCP and H323.
I have a 2 Port E1 card installed in the Router. The first Port is in use and configured for MGCP with a Call Manager 5.1 installation.
However another Pri E1 circuit has been provisoned with 10 Channels on the 2nd E1 interface. As MGCP does not support fractional E1 I would like to config this circuit as H323 while still maintaining my existing MGCP config on the 1st E1 interface.
Any advice would be appreciated.
Ian.
Brandon Buffin Thu, 04/12/2007 - 09:31
  • Purple, 4500 points or more
Ian,
Yes, you can use both MGCP and H.323 on the same router. Simply leave off the "service mgcp" portion of the pri-group command under the configuration for the new controller. So you would configure something similar to:
controller e1 1/0/1
pri-group timeslots 1-10
You can then create dial peers in IOS and a new gateway in CCM admin.
Hope this helps.
Brandon
