Layer 3 at the Edge or user access layer?
mahmoodmkl Thu, 04/12/2007 - 12:18
If u r using layer 3 links between u r switches then u need not define them as layer 2 trunks.Using layer 3 u can get fast convergence than using layer 2 trunk links as stp will take longer time to converge.
Mahmood
e-dennington Thu, 04/12/2007 - 12:42
One of the main advantages is the elimination of spanning tree between your access and distribution/core switches. This eliminates any ports that would be blocking and allows more efficient use of all network links to each access switch. Also don't have to worry about spanning tree convergence or layer 2 loops.
