How To Show Active ISDN Calls with MGCP GW
We recently migrated from CME to full CCM. We converted our old CME into a gateway for CCM.
Before, if I wanted to see the called/calling number on the gateway I could do a "sh isdn active" However, now that it's moved into CCM as an MGCP gateway, this doesn't work anymore. You can run the command, but it doesn't show anything.
You can do a "show voic call status", but this doesn't show the details of who's calling or being called.
CallID CID ccVdb Port DSP/Ch Called # Codec Dial-peers
0xE50E1 3A4D 0x65277580 1/0:23.23 2/2 * g711ulaw 0/0
0xE50F9 3A59 0x6567C2B4 1/1:23.19 2/1 * g711ulaw 0/0
0xE516B 3A92 0x65277580 1/0:23.18 4/3 * g711ulaw 0/0
0xE5181 3A9D 0x65277580 1/0:23.17 3/2 * g711ulaw 0/0
0xE5185 3A9F 0x65277580 1/0:23.16 3/5 * g711ulaw 0/0
0xE5199 3AA9 0x65277580 1/0:23.20 3/1 * g711ulaw 0/0
0xE51A7 3AB0 0x65277580 1/0:23.15 4/4 * g711ulaw 0/0
Any idea on how I can see who's calling whom?
Dave
Overall Rating: 4.5 (2 ratings)
Paolo Bevilacqua Fri, 04/13/2007 - 04:25
  • Hall of Fame,
    Founding Member
Perhaps "sh call active voice compact" works with MGCP ? Probably not.
So the right place to look is CCM I guess.
Gergely Szabo Fri, 04/13/2007 - 08:51
  • Green, 3000 points or more
  • Community Spotlight Award,
    Member's Choice, December 2015
sho cal active voice would only give you the far end side numbers... Problem is MGCP gateway actually functions as an "extension" of the callmanager (unlike H.323 where a gateway is sort of a "fully qualified" PBX sending and receiving calls from another "fully qualified" PBX, the callmanager).
johnnylingo Fri, 04/13/2007 - 12:10
  • Bronze, 100 points or more
I've been trying to figure out a command that lets you do this for years, and haven't been able to come up with anything.
jason-calbert_2 Fri, 04/20/2007 - 11:52
you could do a debug isdn q931 that would show the calling and called number. It would however only show when the call is made or tore down. I think this is as close as your going to get on the router side without looking in callmanager traces.
victor.cwiik Sat, 04/21/2007 - 10:20
Dear Friend,
Try to use the following command:
--GW#sh call active voice brief--
Using this command you go to view all calls active in your GW - incoming and outgoing calls.
Victor Correa Wiik
from SP-Brazil
